I have just moved into a new house and am trying to get my head around the CH/HW system and i have come across a pipe which appears to serve no purpose at all, i was wondering if anyone could shed any light on what it might be....
The layout is as follows....
Boiler hot pipe---pump---i---Zone control valve---HW(cylinder inlet)---HW (cylinder outlet)----i---boiler return line
For those who may be baffled by my crap drawing the mystery pipe is the small " i " . it is a 15mm bore and is vertical and is joined between the pump and the ZCV and runs to a point between the ZCV and the cylinder coil return to the boiler line. there is a stop cock near the top.
Does anyone know what it is for?????
i have tried to reason it out but i just cant figure it out - should it be open or closed?
any help would be appreciated as it may help to solve my other problem - see thread on 10th feb labelled pump/boiler problem
thanks
thanks
