- Joined
- 16 Sep 2007
- Messages
- 1,905
- Reaction score
- 161
- Country
My mistake, I didn't notice.Thanks for all replies.
Think this only rated at 16A, does this matter? most folk seem to like 30/32A
Also if the joist has been butchered with notches over the years drilling more holes is not ideal, TBF a plate should have been usedI don't think we know how old the OP's house is but, to be fair, one does not have to go all that far back in time to the days when all (certainly most) electricians probably were, by the above definition, 'clowns'!
Kind Regards, John
Oh yes, I agree. If there is a notch, or a hole that is in a position which would not currently be acceptable, I would personally usually use it (with a plate in the case of a notch or a hole near the surface), rather than mutilate the joist any further.Also if the joist has been butchered with notches over the years drilling more holes is not ideal, TBF a plate should have been used
How long ago was it acceptable to install cables in a way that risked damage to them?I don't think we know how old the OP's house is but, to be fair, one does not have to go all that far back in time to the days when all (certainly most) electricians probably were, by the above definition, 'clowns'!
Dunno - our 'regulation historians' may be able to tell us if/when it was compliant to run cables, unprotected, in joist notches - which may or may not correspond with what you would regard as "acceptable".How long ago was it acceptable to install cables in a way that risked damage to them?
I remember rewiring LA houses in 85 which had concrete joists with battens on top, we were issued with flattened steel capping to protect the cables , useless but the sentiment was thereDunno - our 'regulation historians' may be able to tell us if/when it was compliant to run cables, unprotected, in joist notches - which may or may not correspond with what you would regard as "acceptable".
However, it is, in my experience, pretty unusual in any house of 'appreciable age' (a few decades) to find cables anywhere other than in notches on the tops of joists (without any protection) - whether that was 'acceptable' at the time it was installed or not.
Kind Regards, John
Did you earth the capping?I remember rewiring LA houses in 85 which had concrete joists with battens on top, we were issued with flattened steel capping to protect the cables , useless but the sentiment was there
Interesting - but I was not actually thinking/writing of 'that recent' - perhaps more like 60s/70s (or earlier).I remember rewiring LA houses in 85 which had concrete joists with battens on top, we were issued with flattened steel capping to protect the cables , useless but the sentiment was there
I can believe it.I think I can honestly state I have never seen properly protected cables in a notch in 40 years of sparking
