Neatening up underside of winder stairs
It looks like there are areas near the wall that might need an inch or more to smooth out the curves. Is that possible?
If you do what i said you wont need an inch ive repeated it 3 times now im off lol
What depth can I actually build up though?
Not an expert, but if well keyed into the existing surface, I would suggest 1" of total extra depth should not be a problem. Have you ever plastered before? Plastering a flat surface is relatively easy, when compared to what you are intending to plaster, even the experts might be struggling with that as you have found in your house. In other words - you might well end up with a worse result than you began with.
I’ve filled a few cracks with easifill…I can see this isn’t straightforward, although I can also see the shape it needs to be. Its the knowledge of how to create that shape I lack - materials , techniques etc
This is my last post on this thread just want to say you have a large crack running along the top which you have failed to mention
This is my last post on this thread just want to say you have a large crack running along the top which you have failed to mention or nobody has noticed and would need sorting before any more plaster is added here is a close up of it for the lads to look at
That crack runs along the joint of the plasterboard 45 degree section and the curved winder which I think is mesh and plaster. There are a couple of hairline cracks on the winder part too
