hello all, first time post. after spending 2 weeks trawling the internet for answers i gave up and tinkered with the box and have thought to post it here for anyone in the future to find useful.
you will need to zoom ion to picture to see what its referring to
REMEMBER ONLY USE THIS AS A GUIDE AND IF COMPETANT TO CARRY OUT THE TASK.
THIS IS JUST FOR INFORMATION DONT MESS WITH ELECTRICS IT CAN LITERALLY KILL OR CATCH FIRE ETC
LED 1 = used for programming new remotes
LED 2 = on when safe is connected to common
LED 3 = on whilst open on JX3 is linked to commmon
LED 4 = on whilst close on JX3 is linked to commmon
LED 5 = unknown at moment
DIPs 1 = enable open function on jx3
DIPs 2 = enable close function on jx3
DIPs 3 = dead man open on jx3
DIPs 4 = dead man close on jx3
AN 1 = press once will flash LED1 during the flashing period press a button on remote until LED1 changes pattern
AN 1 = Keep pressed for 5-10 seconds to wipe all stored remotes
SW 1 = adjust the time open on jx2 is activated for...not applicable when using the dead man ioption on jx3 but still timed on remote
SW 2 = adjust the time close on jx2 is activated for...not applicable when using the dead man ioption on jx3 but still timed on remote
JX1 pinout (please note this is how it is labeled and it is up to you to verify its the exact same as mine)
pin= . . . . . .
Earth [Earth Neutral Live] {Live Neutral}
[ MAINS in ] {Light }
JX2 pinout (please note this is how it is labeled and it is up to you to verify its the exact same as mine)
pin= . . . . .
[Com Open Close ] {+ - }
[Motor ] {24V DC }
JX3 pinout (please note this is how it is labeled and it is up to you to verify its the exact same as mine)
pin= . . . . .
Com Safe Open Close Stop
JX1 Mains in = 240v power from mains
JX1 Light = activates 240v mains out to power a light (check the rating of fuse)
JX2 motor = wiring to motor
JX2 24V DC= aways on outputting 24v DC to power sensor for JX3 SAFE/STOP
JX3 = common to activate the SAFE/OPEN/CLOSE/STOP if no sensors are connected then you still have to wire the common to safe and common to stop
pin= . . . . . .
pin= . . . . .
[Motor ] {24V DC }
pin= . . . . .
