Hello.
I am new to the forum and would welcome some views on a quote I just had from a large nationwide supplier.
Current system is in a 3 bed, 2 bath bungalow, vented HW storage, fully pumped S plan, 9 rads, 2 tanks in loft, 7 yr old Drayton (BG branded) wax filled TRV's. Boiler is Ideal icos 24he fitted by BG 7 years ago.
We have recently bought the property located on the South coast, only 2 of us in occupation 98% of time and do not heat 2 of the bedrooms and 1 bathroom. Heat requirement calculations indicate 11KW ignoring our limited use.
My 2 main reasons for changing the system are; I would like to remove the need for storage tanks in the loft and stop/minimize the currently excessive boiler short cycling.
The quote was £5,500 for a WB 30CDi combi and included the following that I would like a second opinion on:
1. The current boiler is obsolete and rubbish and will fail imminently and cannot be fixed.
2. My CH pipes being under the concrete floor will "definitely" leak with the new high pressure combi boiler.
3. I will have to disconnect (and separately replace) my Mira LP thermo mixer showers.
4. My newly installed Drayton digistat +3 will not work with the new system and I need a "HIVE" to replace it.
5. The new boiler will not short cycle as it modulates from 1W to 30W - I questioned that the technology had improved so much and he confirmed I had not misheard.
6. Replace all 8 TRV's and balance valves as the old ones will "definitely" leak.
7. Gas use will be 30% lower than now.
I will of course now obtain a quote from a small, local, company but would like to know if all the above is correct beforehand.
Many thanks in anticipation.
