1. drain/flush system
2. remove existing boiler
3. supply/install vaillant ecotec boiler
4. remove current hot water cylinder/replace with fast recovery hot water tank
5. convert system to fully pumped
6. fit cylinder thermostat, 2 channel programmer and wireless programmable room thermostat
7.Boiler condense pipework piped to shower waste
8.gas service externally piped to new boiler location
9.system wired, corrosion proofer added and system tested
