my front door lock is broken, recently the key has been getting harder and harder to turn, I just put it down to the locking bolts that slide up and down on the side needing oiled, anyway oiling didnt work so must be the lock. Yesterday I couldnt get in and the key was so hard to turn but as it turned the key snapped off. I got the key out with long nose pliars but now have to use the back door entrance as the front door wont turn so cant lock or unlock. Can I just change the barrel bit or what? I read on another thread here that most standard barrels have a screw holding it in place and you undo that to slide the barrel out, well all I have is a brass plate going all down the side with screws holding the brass plate in place all the way up, would the screw be behind this plate? Any ideas in case you think its something other than the barrel?
