Need to align my tv aerial
31 Aug 2005
Recently put up a good quality aerial and pointed in the general direction of our transmitter.
Seems a bit unhappy at the moment as we have some channels missing on both freeview tv's.
I was looking at one of these as it caters for my sky dish also which i could check( one of my sky boxes has reception issues at times)
This one:
http://www.tvaerials.com/product.aspx?productid=4643
Thoughts help pointers most appreciated!
thanks.
have you tried changing the orientation off the areal??
as in fins now at the side turn them to the top and bottom
and re tune if Necessary
NO i haven't purely because i positioned them the same as my neighbours aerial which was recently fitted and i believe is working ok.
i get 114 and 117 channels in surrey dependent of which off the tuners i am on
has the switchover finished in your area
also worth a re-tune on a different day as it can be effected by the weather in marginal areas
I installed a V10-040 on Sunday for a friend. I didn't find alignment difficult without a meter. Just pointed in the right general direction then rotated slowly for the best signal quality indication on the screen.
Tell us your postcode and aerial type for more specific advice.
Sure its bh22 area. And im using a red tipped antenna cant remember off the top of me head which type but im sure that's the correct for my transmitter!? Wasn't a cheapo it is decent.
BH22 is too vague to give good advice but it tells me that you are using Rowridge transmitter, which I know is "Group A" (red tip).
http://www.wolfbane.com/cgi-bin/tvd.exe?DX=L&HT=10&OS=bh22
If your aerial is pointing towards the Continent, interference is a possibility and it could block one or more multiplexes. There is really no answer to that.
Dependent on your postcode, your signal may be too strong (60dBuV/m is very strong) and that could kill multiplexes just as effectively as a weak signal or Continental interference. An attenuator might be needed at each receiver.
Bad cable and connections can also kill one or more multiplexes, while leaving others working.
Anyway, I don't like guessing games but maybe you've got enough information to work on.
If you need more clues try
http://www.satcure.co.uk/tech/freeview_problems.htm
And is it polarised correctly? (vertical vs horizontal).
