neff oven tripping when changing temp
update
it was lower bottom element tripping rcd.
replaced and is fine but one question
when I went to replace the element that goes around the fan there are 3 wires coming from the back. the photo I took only had 2 wires connected to the element so this must have popped of when removing as it's quite short and can only reach the hole where the element goes. I can't workout where it should go on the element though or does matter? the other end connects to the grill element situated at top of lower oven. this element has 4 connections and is coming off the last one.
in the element around the fan I have a wire attached on prong 2 and wire on 4. this is what I took a photo of.
does it matter if this other wire goes on 1 or 3?
hope that makes sense
everything works but thermo doesn' go off on grill setting - must be cos of above wire
cheers!
