Copy of email sent to neighbour :
Dear xxx
It is a shame you are unable to attend the mediation meeting which I suggested to xxx would be a good idea to arrange, since I felt this would be the most amicable way to sit down and discuss the situation and look at alternative solutions to your problems with installing your boiler and flue.
In the absence of a meeting, I feel it important to make you aware of the building regs that do apply to your proposed work, including the siting of the flue. I therefore thought it a good idea, in good time, to appraise you of these regulations and risks associated with your current proposed siting of a boiler flue on a boundary wall within my patio boundary.
1, Building Regulations, Explanatory Booklet,
http://www.planningportal.gov.uk/uploads/odpm/4000000011249.pdf
Page 12/13, 3.2 :
"If whatever work your project involves amounts to ‘Building Work’ then it must comply with the Building Regulations. This means that if you want to:
- put up a new building, or extend or alter an existing one (e.g. by converting a loft space into living space);
- or provide services and/or fittings in a building such as:
– washing and sanitary facilities (e.g. WCs, showers,washbasins, kitchen sinks, etc.),
– hot water cylinders,
– foul water and rainwater drainage,
– replacement windows, and
– fuel burning appliances of any type;"
".....This means that the works themselves must meet the relevant technical requirements in Schedule 1. There are 14 parts of Schedule 1, Approved Document J relates to Combustion appliances and fuel storage systems" (see 2 below)
Questions & Answers, Page 29, (u)
"If I want to install, replace or alter the position of any type of fuel burning appliance (including a gas boiler with a flue), will the Building Regulations apply?
All Gas appliances: Yes and the Gas Safety (Installation and Use) Regulations will also apply – but if you employ a CORGI (Council for Registered Gas Installers – approved under these regulations) - [now GasSafe .... ] registered installer with the relevant competencies to carry out the work, you will not need to involve a Building Control Service"
2. Building Regulation, Approved Document J
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADJ_2010.pdf
'Location of outlets from flues serving gas appliances' see Diagram 34, page 49/50 illustration H applies - flue siting distances from a boundary dependent on flue type (balanced flue, natural or fanned draught)
3, The Gas Safety (Installation and Use) Regulations 1998
http://www.hseni.gov.uk/l56_safety_in_the_installation_and_use_of_gas_systems_and_appliances.pdf
87 - Regulation 8(1) "....... Gas appliances/storage vessels should be installed so that safety cannot be affected by any future developments, eg building extensions, on adjoining property. For example, a flue should be located at a safe distance from any site boundary, so that in event of any development on a neighbouring site (which could extend up to the boundary), the flue will continue to operate properly and discharge of combustion products will not present a hazard to any person (see regulation 27 and Appendix 1)"
Regulation 27 (5) "No person shall install a flue other than in a safe position"
182 "A flue (including any terminal) should be installed in a position which ensures that it will operate effectively and that products of combustion will safely disperse and not present a hazard to any person, whether in the premises in which the associated appliance is installed (eg by being located a safe distance from vents and openable windows), or in adjoining/neighbouring premises. The location needs to take into account any possible developments in neighbouring property, eg building extensions. Any flue should therefore be sited so as to discharge at a safe distance from any boundary with adjoining premises (see regulation 8 and Appendix 1); reference should be made to requirements in Building Regulations and appropriate standards, as applicable"
Appendix 1, 3 (e) " the terminal is correctly sited; this should include adequate separation from any site boundary to ensure that the flue will continue to function safely and emissions will not present a hazard to any person either on the site concerned or in adjoining property, including in the event of any future building development on adjoining premises (which might extend close or up to the site boundary)"
4. Also see Gas Safe Technical Bulletins 231 & 16
http://www.a1gassafe.co.uk/pdf/TECHNICAL_BULLETIN_231.pdf
http://www.dougiejarvis.com/enginee...nations - pluming - plume management kits.pdf
In addition to above regulations, there are obvious risks associated with a siting of the flue within my boundary and close to my property :
Environment Protection Act 1990, Part III Statutory Nuisance and Clean Air
http://www.legislation.gov.uk/ukpga/1990/43/contents
"Potential Statutory Notice can be applied in the event of justified complaints of statutory nuisance. A statutory nuisance in terms of pollution can include emissions of smoke, fumes or gases, dust, steam and smell as well as noise. The nuisance must be coming from a premises and must materially affect the use or enjoyment of other surrounding premises. If a statutory nuisance is being or is likely to be caused Environmental Health will serve an Abatement Notice under the Environmental Protection Act 1990. It will require the person responsible, occupier or owner of the premises (as appropriate) to stop the nuisance. Failure to comply with an Abatement Notice is an offence and legal proceedings may result. If found guilty of an offence of this type then the maximum fine is £5,000 on domestic premises"
Also potential for Tresspass of Airspace as in Laiquat v Majid & Ors (June 2005) The case went to the court of appeal and it was won solely on the basis that there must be no trespass of airspace (Previously, nuisance, loss of enjoyment etc., were taken into consideration.)
Whilst I am sympathetic to your plight in having limited options regarding the location of your boiler, I am afraid, irrespective of my submitted planning permission and whether it is approved or not, I do not give permission for you to place the boiler flue on the boundary wall within my patio area, which, along with my flat, is delineated in red edging in my Land Registry title documentation, defining the extent of my leasehold land
As a consequence, I am afraid it will be necessary for you to consult with your contractor, who I am sure as Gas Safe registered will be able to help you to find an alternative solution to safely discharging fumes out from your boiler and away from my boundary.
However, should you still choose to go ahead with the work, then I am afraid I will have little option but to take necessary steps in contacting Gas Safe, Building Control at Wandsworth Council and the Health and Safety Executive to make an inspection of the work in order to have the situation rectified, which may result in your gas supply being disconnected and an enforcement put in place to have the flue relocated.
I hope that with further consultation with your contractor, you will be able to find a solution which will be mutually agreeable to everyone.
Regards, xxx
