This actually takes me back some 50 plus years to a loft accessed through the ceiling of the airing cupboard, the loft light was a trailing cable coiled up on the floor of the cupboard with 15A plug. Above the loft hatch was a glass panel in the roof which gave plenty of light in that area but the loft was L shaped and around the corner was in total shadow. It was easier to call down to get someone else to plug the light in.You may be in the loft and someone switches the light off by mistake in the hallway. Then you can just switch it back on on the loft.
But what also works is a switch in the loft which you can see and reach from the ladder before you actually set foot in the loft.The idea is to have the light on before you climb into the loft/attic.
The area is open and flat.But what also works is a switch in the loft which you can see and reach from the ladder before you actually set foot in the loft.
Indeed sometimes it can be tricky finding a good location.The area is open and flat.
No joists around the perimeter of the hatchway?The area is open and flat.
Exactly the same here - and it's never yet resulted in the light being left on up there. As I wrote before, one would have to be pretty drunk to close the hatch whilst there was obviously light still coming through it!my loft light has a pull-cord switch, attached to a roof timber, so that it hangs down over the hatch hole. It is the first thing you see when you enter, and the last thing you see when you leave.
I think that if I had a microswitch on my loft hatch, I would forever be wondering whether the light really had gone out when I closed the hatch. Such switches on my wardrobe doors do seem to need very occasional 'adjustment'.I repeat
