Hi All,
I made a post a few days ago about how to wire my Nest 3rd Gen Heat Link. User jackthom kindly replied and everything seemed great. However I've noticed that the Heat Link isn't turning on the hot water. The central heating work fine.
The original wiring of the programmer was:
http://imgur.com/WDTM5Pp
On my original post I thought the black was the central heating and the grey was the hot water, but after I wire it I noticed when calling hot water the central heating was turning on.
My current wiring of the heat link is:
http://imgur.com/a/KiM3O
When the central heating turns on there is a click from the heat link and a radiator symbol (circled in green on the image below) that flashes on the boiler display. When the hot water is turned on there is a click from the heat link and I can also hear some winding noise from some sort of motorised valve on the side of the hot water tank, but the tap symbol (circled in red on the image below) on the boiler display never flashes, the radiator symbol doesn't flash either:
http://imgur.com/a/1eoPS
For reference, the programmer has the wiring on the back as this:
http://imgur.com/a/VPzpa
So, it seems simple and that the wiring should be working as 5 is getting its power from 2, which is wired to 1 - if this wasn't connected the central heating wouldn't turn on. I'm pretty sure I've got the Nest programmed correctly as if I swap the grey and black cables around I can turn the central heating on by asking the hot water to boost. However I can't get the hot water to turn anything on under any circumstance.
The hot water works fine with the original programmer (which I have replaced because the remote thermostat is broken).
Can anyone help me? Does this seem like the Nest Heat Link is broken??
Thanks in advance,
Andy
Thanks in advance,
Andy
