- Joined
- 27 Jan 2008
- Messages
- 24,923
- Reaction score
- 2,882
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
This may not help you, but I have problems with daughters first house with 3 port valve.
The problem was my diagram of what was inside a 3 port valve was wrong, so my logic was wrong. The problem was diodes and resistors inside the valves give misleading readings.
The problem turned out to be a micro switch inside the valve had stuck, but it took a long time to find.
What had happened was previous owners had latched the bleed lever on the three port valve which kept the heating working, and only when the leaver was knocked snatching it was it noted there was a fault.
I would suggest latch the bleed lever and see what happens.
