Hello all,
I would a very quick bit of advice. I am planning to purchase A Nest thermostat this weekend but I want to understand how I can wire it first with my setup. Please in advance forgive me if I say anything slightly stupid but I have a good understanding of electric circuits so I should be fine
I have included a bit of extra info but this my setup:
My boiler is a Worcester Greenstar 18Ri
I have a hot water tank upstairs in the airing cupboard
My programmer is the British gas UP2
My current thermostat is a standard drayton (the warranty sticker on it expired January 1996!)
I have attached the wiring of the programmer and thermostat but there reason I having a bit of confusion is my current programmer has pins 1,2,3 and 4 with no pin 2 whilst the nest heat link has 6 pins and i believe requires pin 2? Any advice would be much appreciated, I am sure it is probably a common setup.
As a quick note too the cable on the programmer going straight down just connects to a junction box with a fuse which also provides power to the boiler. The cable going up doesn't go into the boiler at all and just goes straight up into the ceiling but another cable comes down next to it into the boiler.
