Ok! But for the sake of this task, matching the wires is the same.Could be a MOMO valve used for hot water zone.....do not assume....
I just told you!!Any suggestions?
Are you sure? That would be quite an unusual setup!The heating is done by a combi and the hw is from a hot water tank.
And yes 100% that's the case. Water tank in the roof feeding hw tank for hot water. Combi does all the heating. The programmer at the moment works, I just world like to you use a nest to save money and rebirth management. Also like said on my phone so I post and as you guys post so quick I only see replies after.
Yes it's built into the old programmer, see the programmer wiring diagram.The issue I have is the up2 has two calls, one for HW and the other CH and they seem to share a common. See picture 1.
There is no common to split, the commons were internal to your old programmerThe Nest though seems to need commons, one for the HW and CH, in not sure what to do about this now. Can I split the common for the Nest, only connect one common and the Nest internally will share the common
NO! You connect it as shown in the Nest wiring diagram.or would i need to add an addtional cable from the boiler?
He's currently typing links to the Honeywell Evohome system!Where's @Dan Robinson when you need a facepalm meme!!
It's 25p now to account for all the extra trouble.What do you charge nowadays Freddo? I remember when you used to be 10p!
