Hi everyone,
Hoping someone can shed some light on a heating issue I've been having. Four years ago, I had a new system installed, including boiler, unvented cylinder, pump, valves, and separate upstairs/downstairs zones controlled by Nest thermostats.
Everything worked fine until recently. Now, when I try to turn on the downstairs heating (either through the Nest thermostat or the app), it doesn't respond, and I hear a clicking noise coming from the upstairs cupboard where the Nest Heat Link and Honeywell Motorised zone valves are located.
At first, I thought the downstairs zone valve might be faulty, but here's the odd part - power cycling the boiler (which is downstairs) temporarily fixes the problem.
This makes me wonder if it's not a simple valve issue. Could it be:
I've tried restarting the Nest thermostats and the Nest Heat links
Thanks in advance,
- A wiring problem between the Heat Link and the valve?
- An issue with the Nest Heat Link itself?
- A problem with the boiler's control board affecting the zone valve signal?
Thanks in advance,
