Hi
I have a Worcester 30i combi boiler which had a Worcester Wave thermostat fitted, which is now longer supported
So I decided to replace it with a Nest 3 generation thermostat. The default setup with Nest and Worcester Bosch seems to be On / Off temperature control. The Worcester wave thermostat uses gas heat modulation to control heating, which works well and is more efficient. The boiler is on for longer at lower temperatures. So I wanted to do the same with the Nest, which says it supports Open Therm
Worcester Bosch uses an (apparently proprietary) EMS protocol to modulate the boiler. The thermostat was hardwired to the EMS socket in the boiler
I used those wires for the t1/t2 - 12v power supply from the Heat link to the Nest thermostat. I also powered up the Heatlink from the boiler 230v supply as per the Nest wiring diagram . The relay in the Heatlink seems to be redundant
So the 230V Live Out has a short link to the radiator LR and the Hotwater LR as per previous setup , as well as wired to the Heatlink
I connected the Heatlink to the EMS socket via this a Nefit Open Therm -EMS adaptor
https://myboiler.com/opentherm/worcester-bosch-openther
After powering up and the boiler operating, the issue is when the desired temperature is reached (say 20 degrees C) the thermostat controls the boiler by switching it on and off 2-3 times a minute. There does not seem to be gas flow modulation. The boiler blue light is always on and the boiler status seems be switching from "Waiting" to "Heating" - the flame light comes on ;. The radiator temperature fluctuates around 50-58 degrees. I can hear a clicking sound when the flame light comes on so there must be a relay switching the gas on and off
This doesnt seem to be satisfactory - I would rather revert to the default Nest configuration . But I would just want to check if the setup is OK
