I wired up my Nest (3rd gen) fine in my old house a few years ago, but have just moved into a new build and the heating system is WAY more complicated than the last one! We have a boiler in the garage, hot water cylinder in a cupboard upstairs, programmer in the utility room and two zones with a thermostat each upstairs and down.
I've opened most things up and it seems like the most logical place to wire the Heatlinks (I'm gonna buy a second Nest for the other zone) is in a box on the cylinder which has the following in:
Am I on the right track so far?
If so, there is a block there for Room Stat 1 and Room Stat 2 with junctions for:
L E N L/1 N N/O
With wires going into L, E, N and N/O. I assume these wires run off to each of the thermostats - right so far?
So would it be a case of pulling out the L, N and N/O and then wiring the Heatlink L and N into the L and N junctions and the 3 into the N/O? What about the 2 in the Heatlink, would I wire that into the N also? Would it matter which N junction I wire it into?
Assuming I'm on the right track so far, I could then take the L and N I previously pulled out, and wire them into the T1 and T2 of the Heatlink and then wire the other ends into the Nest?
Is it possible it's that straight forward?
L E N L/1 N N/O
