(Re-submitted from another thread as probably confusing to mix the two problems although they seem similar)
Hi
I have a problem with Netaheat 16-22 (20+ yrs old). Started shutting down allowing rads to go cold. Heating limps along on minimum setting firing up OK but for short periods only but if I crank up thermostat on boiler it shuts off completely very soon and outer casing gets very hot to touch. Then rads go cold. All rads warmish on min. setting. Tried draining system and now have put Superfloc in via F&E. I presume there's a problem with boiler overheating causing shutdown? Could this be scale in the heat exchanger leading to reduced water flow? However problem showed itself fairly suddenly which is against that. Getting some noise from boiler but not very loud.
Noted today that it failed to come on again this pm even on minimum setting. Started up on re-setting - which it always has done during problem.
Pump seems to be working inasmuch as system didn't drain down without pump but drained well with it on and all rads get warm on min setting. Haven't checked it otherwise - dunno how. Don't know about motorised valve or where it is or how to judge if its working OK. Evidence of sludge as rads are cooler at the bottom. But on allowing water to run through from F&E tank it ran clear quite quickly.
I was going to leave Superfloc for 7 days then try to descale boiler with DS-40 for 12 hrs.
Any ideas? I feel the boiler works OK but it is in need of a declog or something.
Cheers for any help
Grahame
Hi
Cheers for any help
Grahame
