Explain why you think it should.
Becuase when the live or neutral touches the earth or a fault occurs to earth it will always flow to earth so it doesnt matter if the earth bar is just one whole bar because noExplain why you think it should.
For what reason are you asking these questions?
College, obviously.
If you're struggling, don't ask us for the answers set for you. Research, the internet is full of information, and if you still can't find anything then give us an idea of what you do know and ask us to help fill in the blanks.
You won't get anywhere if you revert to asking others because you don't immediately know the answer.
I totally disagree with this reply. This forum would be the first place I would come to to ask for clarification on anything. We have experts with more or less instant opinions or facts with knowledge of all the statutory and non-statutory documents available. Let's not lose the intention or vision of why this forum was created. Using this forum IS researching.
Small print: Apologies if barnies has been a pest in other threads but I just thought that needed saying.
barnies said:what would be best for wiring 2x 3kw heaters would it be better to wire a 20amp radial then use a fused spur for the heaters then?
barnies said:Why is a mcb chosen higher than the current taking in a circuit say the circuit was pulling 18amps you would a 20amp breaker wouldnt this 20amp breaker not be to high to trip because the circuit is pulling 18amps which less than rating of the MCB? how does it work why are they chosen higher?
Matter what happens the fault will go to earth anyways? Is that correct?
