neutral for room stat
13 Jan 2006
Merseyside
i have just run wire from boiler to room stat in twin and earth only to find I also need another neutral on the stat, Honeywell t6360. Can I just pick a neutral from another source close to the stat rather than run one from the boiler switched fuse spur as shown in boiler diagram (Combi). Thanks
you only need the neutral to make the stat more accurate.
it still will work just using the two switch wires.
id sleeve the earth wire an use that as the neutral ;)
edited: mistake removed
are you thinking of suggesting doing something with the CPC?
A T6360 is a standard mechanical stat so it will work in a fashion without a neutral. NO YOU CAN'T USE THE EARTH AS A NEUTRAL onlyfitidealboilers should be strung up for even suggesting it !!! :eek: :eek:
No you cant pick up a neutral from a local source as this would be potentially dangerous when work was carried out involving isolating the double pole fused isolation point a stray neutral could introduce voltage into the supposidly isolated circuit which could lead to electrocution & death
my advice either leave N dissed or run a 3 & E cable ;)
why not. why do you need to earth a room stat?
seen it more then 100 times no earth on a stat, your lucky to get a neutral on most!
HAVE A LOOK AT BS7671 for Electrical installation a protective conductor must never be used as a current conductor if a stat does not need an earth, the cable feeding it should still be earthed at the other end!! :rolleyes:
Make life easier for yourself and fit a digital stat, no neutral required just 2 wires and a battery to switch it.
I would just follow the manufacture instructions in that case an if they say
it doesn't need a earth I dont give a FU*K what the regs say.. ;)
trade the stat in for a hard wired digital type line in, line out, no earth, no neutral, batteries do the switching.
the stat he has already got will work with L in and S/L out. He will just lose the Anticipator.
I don't know how much work it would be to pull in some 3+E. Maybe the existing cable could be used to pull it.
It is very bad practice, and unsafe, to use a borrowed neutral or to use a CPC as a live conductor.
