Hi, I'm having a new boiler installed in a new location the other side of the house. The current setup is an old convential boiler with pump/diverter valves etc.
The current circuit is a 6a MCB feeding the boiler / burglar alarm. Coming from the consumer unit is 2x 1.5mm cables on that MCB feeding a fused connection for the alarm and the other cable wired straight to the boiler wiring with no FCU that I can see at all which isnt good. At this point the wiring goes off to thermostats and pumps and will be a big task to identify so the plan is to get rid of the lot at the consumer unit.
I have an easy route to the new boiler location (under the floor) and a roll of 2.5mm T+E, would there be any issue terminating this to the 6a MCB other than being uncommon? I would also replace the wiring to the FCU for the alarm with 2.5.
