I help maintain a village hall which needs a new boiler. It was built 30-40 years ago with a single pipe system with one loop feeding all rads. There are about 6 large rads in several rooms all on one floor. The main iron pipe is about 3” diameter and mainly mounted exposed at skirting board height.
If the floor mounted old boiler is replaced by a new wall hung condensing boiler of around 40kW is it legal/practicable to retain the single pipe system?
What kind of further life would be expected from these pipes as no problems/leaks are evident apart from one rad being cold, but may be just because it is full of air and can’t be bled due to seized bleed screw.
In the toilets the 3” pipes run through them to provide some heat but it is inadequate so we may add 2 small rads for this. Also there are 2 small rooms needing rads but need to divert the loop a bit for that. Would the need to do these extra rads change the above decision on whether to retain the single pipe system..
Rather fearful of the work involved in ripping out the pipe and replacing with say two 22m ones. Fortunately aesthetics is not a big issue but we do need to consider that a fairly elderly clientele use the hall and so may need to consider protecting the hotter pipes and rads against contact by them. Do skirting board levels pipes have to be protected like this as difficult to see how a person can easily touch one with bare skin unless stand against wall with no socks/trousers on.
