nalle59 said:
Hi All
I appreciate all your views , it just shows ,talk to 10 heating engineers get 10 answers ...well nearly ..now ofcourse having all your views on this we don't need to waste heating engineers time to discuss this ! ofcourse having a lot of hotwater on tap is wonderful ..it is not easy desicision as one has to think of the future buyer too and their requirements not only ours .
Dr Drivel ,how much of the gas pipe needs to be 28mm? the gaspipe is already 22mm from the meter to the boiler .
The Vaillant ecoTec 937 is fairly new model and we looked at other postings on this boiler so this and others with heatbank may be the way for us .
The 937 is a 837 (been around a time now) with an additional backplate with a tank in it. You will not be disappointed and Vaillant are a quality make. In the field the feedback reports are good. They will fill a bath quickly with no problems at all and as fast as a cylinder system.
A heat bank delivers the flow and pressure brilliantly - as much as the mains pipe will give. If you go for one, go for:
- an integrated CH & DHW version.
- Have the CH circuit on a
smart pump, like a Wilo Smart or Grundfos Alpha,
- have TRVs on all rads - then no room stat is needed.
- a separate CH zone can be brought back to the heat bank, to keep off sections of the house that don't need heating.
- Have a direct heat bank version
- Say use a Glow Worm Hxi boiler (Vaillaint underneath).
- Have a Magnaclean filter on the CH return to the heat bank cylinder.
- On the CH circuit have a check valve after the pump and one just before the boiler (this one preferably springless) then no gravity circulation into the CH circuit in summer.
Gas pipe sizing:
http://tinyurl.com/38v6f9
Have a dedicated line from the meter to the boiler - no tee offs.
