New boiler
DP
10 Dec 2003
Glasgow
A client has a system Vokera boiler and an unvented cylinder. The house is a recent built property and there are a few issues.
1. reverse circulation upper landing radiator
2. UV cylinder bursting
He is thinking of getting a Vaillant 937 or a Viessman. What do the regulars recommend.
I'd recommend investigating the existing problems first...
Then I'd consider looking at my other options.
How recent - within the last 10 years? If so the property may be covered by the builders warranty.
Reverse circulation upper landing radiator
Do you mean that the TRV is on the return end instead of the flow end? That does not matter. Just make sure that, if it is a single direction TRV (one arrow on the body, not two at right angles) the arrow is pointing away from the rad.
Definitely a warranty problem.
Reverse circulation as in it is piped up wrong , Ch works when HW on as in not all the ch returns have been commoned ?? 3 T rule ??
UV burst ????????? never dealt with Vokera , but from what others say there not a bad mob to deal with ?? how come u posted in here ?
New build should be a come back on builders surely ??
