We have built a new brick wall that joins an existing wall at right angles. Right up to the corner where the two walls meet, by bad design, the brick layouts do not match, so that we have two halves at the same level, and above we have two wholes at the same level etc. I proposed that we cut them vertically and we join them, even with wall ties in between, but I was told that would create a "rip joint", which is not building regs friendly.
What we have done instead is we extended the new wall to go just past the corner with the old wall, and then create a new corner, right up to the old wall and with the right angled bricks trimmed about 1-2cm because that's how it has worked out.
Can you please advise me if this construction is sane? I have drawn a top-down view.
