That's the Ferroli train of thought though dude - Any boiler is safe when its sat there in Lockout.
To the OP, you mention pipes would need to be chased in, and then a combi to fit in a kitchen cupboard. In all honesty some manf will tell you about their smaller footprint boilers, what they don't tell you is the fact that you will see the flue at the top, you need to have access to the filling loop, isolating valves, limescale reducer.
If the boiler is going into a larder unit, then great, if its going into a 720 wall unit, don't expect it all to be hidden.
If you still have an airing cupboard - perfect location.
Has anyone measured the incoming cold water flow rate and dynamic pressure?We ... want to replace our existing boiler/tank set up with a combi boiler.
I'd probably say an Intergas Combi but you won't findan installer! Well you may if your lucky.
Go for a Vaillant you will find lots of approved installers I would imagine
There are plenty of us who will install Intergas boilers!
Tony
So are you a quote counter who wants 10 to call round and waste a couple of hours each? Why are you not content with the usual three?
I ask a lot of questions and give emailed budgetary quotes so anyone I do work for does not have to cover unnecessary waste of time visits to quote collectors!
Furthermore, most installers will travel at least up to 30 miles to install boilers and further when there is the A1M or M1 motorways nearby.
Dan lives in Herts and does most of his work in London.
I go to Potters Bar and St Albans and Welwyn as normal areas. Not very far from NW9 !
Tony
