Could you expand on your answer please
And how many houses have you worked on ?????Before I chip in with my sixpennyworth I'm not sure when you mention modulating whether you mean adjusting a boilers output between the maximum and minimum output settings or adjusting flow temperature according to demand.
Additionally, do you mean mark/space ratio control to be a description of TPI where the room control records heat up time and adjusts cycling to suit, spreading the ON periods as far apart as possible while maintaining the desired target temperature? It could be taken as the boiler's own anti-cycle delay between firings.
Fankly my personal opinion is that the differences in operation are minuscule as gas is so cheap. It is easy to show a calculation, an imaginary situation, where simple ON/OFF controls linked to a condensing boiler in non-condensing mode with a 5 minute anti-cycle delay operating three times an hour will be cheaper (by fractions of a penny) to operate than if the boiler ran continuously in condensing mode without cycling matching the load exactly.
eg 5kw put in in spurts is the same as five kw trickled in as 15 minutes of off time through cycling conserves more fuel than the latent heat harvested by condensing continuously even with cycling inefficiencies added and without operating flue losses included. The small overheat and underheat temperature changes with ON/OFF are hardly discernible in the comfort of the user as combination boiler users know very well.
For me, I see these as two elements for the boilers overall control/feedback system - I'd expect (assume through lack of knowledge!) that the boiler will modulate its gas-flow/burn rate/whatever is the measure, to achieve a target flow temp; in turn that target flow temp will be managed dependant upon demand, external temp if WeatherComp is in the mix, etc.Before I chip in with my sixpennyworth I'm not sure when you mention modulating whether you mean adjusting a boilers output between the maximum and minimum output settings or adjusting flow temperature according to demand.
Does that make sense?
Our house is of post-war solid wall construction, and due to the layout most rooms have 3 outside walls. It does not retain heat well! As a result, and due to orientation, my daughter's bedroom can drop to a much lower temp. than the rest of the house overnight - my plan is to use the Hive TRV's to keep her room from freezing without the system heating the rest of the house unnecessarily. It will take a bit of faffing with Hive settings but should be worth it.
