B
breezer
pulling the service fuse is NOT a good idea
beanhead said:Surely pulling the service fuse can't be that risky?
Assuming you have switched your Fuse box/CU off then there won't be any current being drawn from that side of the feed and therefore you shouldn't get any arc'ing when removing or replacing the service fuse?
Also assuming of course that you cover anything exposed by removing the service fuse.
true familarity with the existing wiring is a good ideafubar said:beanhead said:Surely pulling the service fuse can't be that risky?
Also assuming that you have correctly identified and turned off any other consumer units connected via any henley blocks or (heven forbid) wired in parallel to the supply side of the main switch.
they would have great trouble proving that you were the one who pulled itfubar said:Also assuming that the REC doesn't find out and sue you for breaking the seals/stealing their electricity.
mmm reinserting a service fuse against a dead short from a miswired henly block sounds like funfubar said:Also assuming that you check all the above again immediately before you put the service fuse back in.
And assuming that you are actually competent to do whatever it was that you did while the service fuse was removed.
fubar said:That's six assumptions. I'll let you decide on the combined risk for the average DIYer.
plugwash said:they would have great trouble proving that you were the one who pulled itfubar said:Also assuming that the REC doesn't find out and sue you for breaking the seals/stealing their electricity.
fubar said:...partially blinded by arc light.
breezer said:"it is an offence to tamper with the fuse"
