Fair enough but just to clarify, if you have a combined sewer it means the rainwater goes to the treatment works but since they can't usually handle a huge volume of rainwater, they basically have to chuck it all either in the sea or the river every time there's a decent rainfall. If it was only rainwater that would be ok, but the rainwater is flushing all the untreated sewage through into the river as well.Yeah Thanks for that John I understand and appreciate your view I appreciate what you are saying but I believe the gravel will work to some extent then the drainage within will take excess to the combined sewer then away to the treatment works with the sewerage so no issues with causing any pollution to river etc
Just to clarify the sewerage works don’t Chuck the untreated sewerage into the river or sea under any circumstances
Where we live the problem is quite bad hence it making more sense for us to drain into a small depression in the garden.
Hope that makes sense although it may not change your view. Cheers, John
Let’s just get back to the point here I’m on about draining 20sqm of driveway to a 25sqm gravel area which will take most of the water and excess will run away down drain I’m not talking of draining a swimming pool
I know it's not of interest to you but replying for others' benefit.Let’s just get back to the point here I’m on about draining 20sqm of driveway to a 25sqm gravel area which will take most of the water and excess will run away down drain I’m not talking of draining a swimming pool
You've already been told multiple times it's unlawful for you to do so. You've also said you're going to do it anyway.
Instead of trying to get validation on a public forum, why don't you just quietly get on with it and hope that no-one notices? Not sure what you're expecting people here to say to try and put your mind at ease.
