I have just ripped out some old worktops and replaced with new and at the same time decided to replace the sink, oven & hobs. The hobs sat on top of the worktop and the oven was seated into the unit below. They were both hardwired into a point at the back of the oven on the wall. That circuit has a 32amp fuse and it never tripped even with the oven and hobs all on at the same time.
My new oven has come with a 13amp plug on the end of the lead to go into a standard socket but this would mean the cable would have to come through the new work surface and then plug into the nearest socket which happens to be part of the 'cooker' switch panel with red on/off switches about 8 inches above the worktop.
My question is ' can I remove the plug from the end of the cable and channel the cable in the wall to the back of the socket and hard wire it and would this be against the "code" ?'
Unfortunately the the combined totals of the hobs and the oven exceed 32amps. They actually come in at 36amps when all being used.
Any help will be most appreciated.
thanks
thanks
