oven hob extractor
You've already said that the oven requires a 13A supply and that the extractor and ignition need a 3A supply each.
So, now you're asking wheter all three can be connected to the same point?
Lucia.
That's great. So would it be possible to wire all 3 into the same fused cooker switch supplied by the 6mm cable?
You will need to down fuse for hob and extractor, so not really.
You can have your cooker control unit(CCU), isolating all three appliances but they must be installed in a circuit that will offer the 13A supply for cooker, then the 3A supply for both hob ignition and extractor. I would suggest by a socket outlet connected up to the CCU then take a fused spur from the socket outlet to supply both hob and extractor.
Sorry should of said itll be 6mm up to the switch then 2.5mm to the fused sockets from the switch.
