New engine and citroen van
Just needs regular grease. every time they are removed and refitted, always use grease, or next time will be the nightmare.
Regular grease is quite useless. Use copper grease. I can guarantee you it will never get stuck or your money back.
front screws had all gone, replaced by cable ties. It took me nearly two hours to change the bloody oil!
If the ties work, don't see why you need to use screws. Cut down on oil changes, then you won't have to worry about the 2 hours. I do 5 hour oil change every 10 years. The cars purr like champs.
Do you understand the difference between copper grease and LM grease? Why 1 is used where and why? Yes you can use copper grease, but LM will do just as well, it is in a box section.
Why use cable ties if the screws work, greased. Ties work as a best substitute, not as 1st choice.
I don't. I use copper grease, or rtv depending on situation. I used rtv for the ac drier bolts and thermostat bolts because the upgraded ebay bolts were stainless steel. I did use the other grease on home window catch.
Copper grease isn't great for dissimilar metals because the copper in it conducts electricity. It works best for steel-in-steel applications. It's also pretty useless for high temperature applications like brake sliders.
I use copper grease on exhaust. It's pretty high temperature, so high I get a nice bit of smoke. It works beautifully.
But you feel able to lecture on tracking?
For your information, copper grease is used for lube purposes, in higher temperature environments. The grease part will run/melt away and leave the copper part as a lube. LM grease is for less high temperature areas where the grease will stay as a body to protect.
Coper grease was always used for the contact parts of brake pads, but its generally been replaced by other more specialised "greases", but nothing wrong with it on older style brake pads (back and wings), but its definitely not to be used on or near rubber component.
Just for reference ( courtesy Mintex).....
For caliper slider pins, silicone grease only
For other brake parts and pad backs, white ceramic grease.
John
Of course. I filled the tie rod arm the rod screws into with copper grease too.
The information doesn't change my using copper grease. High temperature, low temperature, I use it. I even use it on the screws for my splash shield. A dab of copper grease gives me happy feelings. The MOT guy was a bit puzzled though. But he could not fail me.
I have always used it on the sliders and backs of brake pads.
It's as good as anything for the backs of pads, because it sort of bakes-on, and forms a bit of anti-squeal damping. For slider pins, I used to find it went hard fairly quickly, and made them quite sticky, so I went over to ceramic grease, which seems to stay slippier for longer.
But then, information about changing your oil more often than every decade didn't change your feelings either...:rolleyes:
