Just finished a wedi wetroom. Wedi board on the floor and walls.
Got a tiler in to stick the tiles to the floor and walls & grout.
Floor adhesive: Ardex 5001. This is good stuff. Used for swimming pools.
After 48 hours of the floor tiles going down, some of them (2) have come loose (after I stood on them).
I've taken some pictures of the tiles surrounding the ones that came loose. The adhesive bed does not appear to meet the bottom of the tile:
http://i67.photobucket.com/albums/h316/goodproducts101/IMG_0498_.jpg
http://i67.photobucket.com/albums/h316/goodproducts101/IMG_0499_.jpg
http://i67.photobucket.com/albums/h316/goodproducts101/IMG_0500_.jpg
Should the ribbed bed cover the whole tile?
Could the lack of adhesive contact have caused the tiles to come loose?
More importantly, how can this problem be rectified?
If I leave the remaining tiles, will they eventually come loose?
Should I pull the tiles up and re-lay?
Whether the remaining tiles come loose depends on how they're fixed I suppose. I could just leave it and re-fix any tiles that do come loose in the future, but then I'd have to re-grout, and this would stand out, so I'd rather get it done properly from the start.
My tiler has apologised after seeing the pictures but I'm unsure of how to proceed. When tiles go onto wediboard, they're on for the life of the tile. If you pull a tile off wediboard, the cement backing on the board comes off (you can see some of the blue styrofoam in the picture). You can't re-tile ontothis, so the wediboard has tobe replaced. This is the story according to Wedi (I have rung them).
So If I pull the floor tiles, I'llhave to replace the wediboard and re-seal with wedi tape - which costs a great deal.
My tiler has asked me to tap on the top of the floor tiles and listen for a hollow sound. If I get the hollow sound, then the tiles is not supported fully. This I can believe, but the test is a bit subjective, and from what I've seen of floor tiles before, they can break at the edges if they're not supported there. The tap test would not detect this (correct me if wrong).
Thanks.
Thanks.
