it would still be internal mate just running up other side of wall with other exsisting pipes
glasgow is a nightmare for metal getting taken for scrappys
Hi mate , i have been looking over your post regarding your flat gas supply, i used to work in the gas industry for years, i have found that galvanised steel risers laid internally are the hardest of all to lay around old glasgow tenemants where thd close is littered with electric cables and other services that are older than the gas supply which is feeding ur property and pose more a risk than the new riser which has been laid through your step.tge route of a new riser isnt just that way because it looks better, it all depends on ur original meter position.most risers these days are painted like for like with the close. The gas board these days are improving there service and supply, its more than the water and electric with there old dangerous systems. The workmen in your close might nt be the sharpest tool in thd box but from your pics there work is spot on
