Sorry I can't start teaching English, so I agree with everything you say, whatever that is.You said to someone asking about 20 year old doors to put on gloss or whatever top coat without an undercoat
That's your advice
Its shoddy advice wether it's one coat gloss , one coat satin , oil , water based , one of the latest wonder all in one paints .....
A year or so after a decoration you might consider putting on a solo , once , high gloss , satin paint ......but it's dodgy
In fact using a solo paint , as poor as they are is a better idea than using ordinary top gloss which is your latest answer ....at least once and solo paint is thick enough to give you a short term solution , high gloss is far thinner and without an undercoat .....your suggestion ....on older surfaces ., 20 years ...its far more likely to fail , grin , flake etc etc
That's what you suggested
There is no point in going down further rabbit holes on this matter
Regards
In fact, I go one step further:
Anything that needs painting must be sanded down with 5 different grade papers, 2 coats of primer, 2 of undercoat and 2 of finishing paint.
Rub down between coats.
Total cost to paint a door = £500/£600.
This is what books say, same as pilot holes and countersink for every screw going into wood.
Real world...
