its about 2 meters away,but also one metre lower - the boiler is in the garage and the cylinder is in the airing cupboard which is next to the garage but on the 1st floor. Pipework wise its got to be 3.5 meters ish.
Rule of thumb on gravity cylinders is 3 foot thermal centres , centre of coil centre of boiler ! = 3 foot approx !!
some cylinders are next to the boiler on a raised platform , some older cylinders had coil connections wider apart , newer ones close together !
Been in builders merchants a few times when some have brought cylinders back complaining they do not work or take longer to heat up ! lost ther thermal centres !!
Reheat time is not really important to me or my family, i was purely thinking of gas usage, thinking that if the cylinder would heat upto 60 degrees in 30 mins as opposed to 60 mins, i would be saving alot of gas over the whole year.
Already done. Cavity done, loft 300mm, 70mm bag on cylinder, and A rated windows. Kindly done by the previous OAP couple who lived here. I presume they got it for free.
As far as i see it there is no room for improvement on the insulation front.
