New house - flat roof
30 May 2005
Kent
Vague I know ... but I am due to look at a house built in 2012 with a flat roof (in the flat roof capital of the U.K. .... Cheltenham) - are modern flat rooves an improvement on their counter-parts of years gone by o, or still grief?
How much (if possible) would it be to strip the flat roof off and put on a "proper" roof on an average house? Any info will be gratefully received.
Why in gods name would you buy a house built in 2012 and bung a pitched roof on? Utterly bonkers and living in the past.
There is nothing wrong with flat rooves per se, the workmanship is the key to success. But then that applies to pitched rooves though a flat roof is easier to cock up.
The lifespan will largely depend on the material used. Lead will outlive you as will zinc most likely. Even the cheapest materials should give you 20 odd years, if applied well. But I would expect a new dwelling to have a finish that provides a longer lifespan than that.
So find out what the material/system is.
If it were me and once I'd seen the house if I was still interested, I would be getting a long ladder and having a shimmy up to have a look, then take some photos and post back. Unless you can see it from the ground.
But what I would not be entertaining, is changing it to a pitched roof, I would walk away before that.
