Nicetoseeyoutoseeyounice said:...Have found my digi camera so will take pic of under sink tomorrow...
Who are you asking? The OP is not a plumber.TicklyT said:Can the small bore flexible tail be replaced with larger bore copper pipework?
There might be, and there might not be. Do you know that this will cure the problem, or is this the suck-it-and-see method of plumbing?There may be enough space on the base of the tap to fit, something like a 1/8 BSP nipple bored out to about 8 or 9mm and hard soldered onto a reducer and onto 15mm pipe, so the length of the restriction is reduced to maybe a couple of inches. Some taps have this type of adaptor fitted as standard instead of more restrictive flexible tails.
You're a man after my own heart, nickso (assuming that you're a man).nickso said:do it right from the start in an easy and accessible fashion and less problems may be encountered in the future
