S
sodthisforfun
Well, then I should imagine with soil improver then you should be ok. I really would mix some organic matter in there, it is the best solution.
If you live near any farms or riding schools, they often give manure away - or use something else.
If this is your home for some years now's the best time to do it properly. It's much harder to improve clay soils after you've turfed, see your neighbours flooded lawns for example. The fact you're starting from scratch is much easier to sort it out for a good healthy lawn that shouldn't give you any trouble. Just try not to cut corners, although tempting!
