Building regs - and common sense - require that gravity feed should have a thermostat on the hot water cylinder coupled to a motorised valve that shuts off the flow when the water reaches the required temperature. Mine already has this although it's never been wired up!
You need to check some other points too so your system complies.
5.2)If the new boiler or storage vessel is designed for
gravity hot water, or it is impractical to convert to a
fully pumped installation, provide the following
controls:
a) a cylinder thermostat & zone valve to control the hot
water and provide a boiler interlock.
b) a room or programmable room thermostat.
c) a programmer or time switch.
d) TRV’s on at least all radiators in the bedrooms.
6) Any Boiler Management Control System that meets
the specified zoning, timing & temperature
requirements, is a wholly acceptable alternative.
This is from a leaflet published by the Association of Controls Manufacturers. (ok a vested interest perhaps, but it comes from the building regs.
Yes, I'm going to plumb the kit in myself and get a registered oil engineer to commission it. Worth the cost, not only to get the system running at best efficiency but to provide certificated evidence of a proper installation when it comes to selling the house. Solicitors are quite hot on this, as Oilman pointed out earlier.
Sounk OK to you, Oilman?
Legally speking, the engineer can commission it, but only after seeing a document from either the building control department, or from a registered installer (OFTEC CD/10) stating the installation complies. A registered person can only self-certify (ie their own work), so they aren't entitled to certify someone elses work. If they do, but it didn't comply, they will be liable for the consequences. (Like financial).
East Anglia is a fair sized place, which part of it are you in?
