I am installing a shower and want to run a dedicated hot water supply in 22mm pipe to the pump. The cylinder is covered in a hard foam insulating blanket and I don't want to break it off to see if there are blanks / cutting points. Where on the cylinder should I cut the hole for the new supply?
Many thanks
Many thanks
