Hello.
I would like to add a new outside light. I will feed the light from a consumer unit in the garage. The questions I have are:
(1) Can I simply add the new light circuit (containing only a outside light with PIR, no separate switch) to the MCB which is already supplying the inside garage lighting (fluoresent strips)?
(2) The light will be on an outside wall ~1ml from the garage. Can I simply ran the cable along the wall then up into the outside light? Or does the cable need to containing in rigid tubing?
thanks
ed
thanks
ed
