New oven tripping rcd
If you feel confident and safe, turn off the red main switch on the consumer unit (bare in mind the terminals/wires on the main switch are still live, so don't touch anything.
Remove the front cover and take a decent photo with flash on.
We are interested in the bars at the top with the black & blue wires. Are there 2 or 3 ?
We are also interested in the whole CU wiring
Do this.
If you cant/wont do that, you need a spark.
As mentioned above, we suspect the RCBO white lead is in the wrong neutral bar.
No we do not. In any case, the CREAM functional earth wire goes to an earth busbar. If it were connected to a neutral then I suspect that may cause a problem - but only a complete numpty would do that.
Nore likely the RCBO's neutral is on the RCD's neutral and not on the supply neutral.
Why would someone put just the cooker on an rcbo ?
I could understand it if it were an MCB ?
Too much earth leakage causing a built up and the rcd to go?
Anyway it's a different cooker now.
I guess the solution (if only 2 neutral bars) is to move it to a spare way on the right hand side.
As there is no spare MCB, may as well use the RCBO
I'm sure BAS will be along in a minute with his "it's anybody's guess" screen shot.
Off the top of my head, my best guess is that as ovens contain heating elements which are well known for causing RCD trips, it was done to stop a RCD trip taking out all the other circuits. Given the OPs problem, that may have been a prudent move (although actually it seems to be the cause, rather than the treatment).
Perhaps another possible scenario is that the joker who originally fitted the CU cut the bus bar too short and so those "spares" on the left are unusable. The sparky only had an RCBO in the van, so fitted that instead of acquiring a new busbar.
Who knows? Anyone else got any bids?
well if your feeling confident enough, with the power off
Remove the blue lead coming from the cooker rcbo, thats going to the top neutral bar and put it in the top blue RCD terminal next to the cooker rcbo .
You need to ensure both cables are gripped well and tight.
Try and pull the cables out afterwards, to ensure they are tight
This is probably the easy solution
Easiest but may burn my house down? Is it the right thing to do?
Edit: how do you know that thin one is in the cooker one? I can't see it go in there!
Ok, so there is a thin blue cable that goes into the back of the oven one, but I can't confirm it's the one you highlighted. It goes behind the master, then looks like it isn't the same cable.
Edit: yes, it is the same! Just moved it and the one you highlighted goes into the oven one.
So take it from the top right rail, put it into the rcd?
