Good Afternoon
We are considering replacing our current gas cooker with an electric one, We know a gas engineer that has offered to remove the gas one and make safe the connection etc.
We will be using an qualified person for the electric connections, but just wanted to check what we currently have will work for the oven we are looking at or does it need upgrading/ or pick an other oven, if it does need upgrading we need to get housing group permission etc so wanted to check before going ahead.
The oven we are looking at is a 9.6-10.4 KW double oven by hotpoint. The breaker in the box says 32MA on it but the list on the box says the cooker circuit is rated for 40amps. Having looked at the manual for the oven online it says to use a 6mm2 cable.
Do you think that cable and breaker will be okay ? it will go into one of the oven juntion boxes behind the oven, which is in turn fed from a cooker socket on the wall (with the big red isolation switch), which also has 13amp plug connection.
Thanks in advance
Thanks in advance
