sorry didnt notice your double post- the usb thing is the wifi client for the pc- you do not need this during set up, put it and the cd with it to one side for now.
You will be connecting the pc and router via the ethernet cable. Look for the ethernet port on the back of the pc.
I see that as i write this you have reposted. Will read you 12.09 post and then edit this one
EDIT_______________________
ok the info one the overclockers site is for people that have a router with no modem so ignore it
You say that you connected the telephone cable to the belkin which means that you have a modem/router- good- connect it
The yellow port is normally for connecting to a cable modem- ignore it- I havent seen a yellow port and adsl (telephone) port before on the same box.
Next connect the yellow lead to one of the four ports (doesn.t matter which) and the other endto the pcs network card.
wait 10 seconds and open Internet Explorer (aka IE)
You should get a page not found error
In the address bar type
192.168.2.1
and hit return
This should take you to the belkin config page
If this does not happen then follow my 11.54 post
if it does follow the 6.47 post
Additionally you will have a series of lights on the front of the router- untill set up I would expect the adsl light to be red or yellow but the 1234 ethernet lights to be flashing green
Green is good
if you post the model number of the belkin this will help us to be more specific
once the above is done we can work on setting up the usb wifi client
BTW the old modem MUST be unplugged in order for the new one to work- two modems cannot work at the same time
cheers
192.168.2.1
and hit return
Green is good
cheers
