I'll try to explain as best I can!
Newish build house (1994) has 10mm microbore heating pipework, gravity fed CH system.
We have just converted out garage into a day room and added a radiator, I decided to tap this into the radiator feed from the bedroom above, firstly because it was a much easier route but mainly because all the upstairs radiators are small (500x500) where as downstairs rads are large (1200x600) and some doubles. I know that there are separate manifolds for upstairs and downstairs so figured the downstairs already had a large load, plus the house isn't the warmest so didn't want to hinder any existing downstairs rad, remembering it's all microbore.
Problem is the new rad (1200x500 double) doesn't get very warm, all the other rads are hot to the bottom after about 10 mins but this one is only hot 1/3 of the way down. Strangely the rad it is connected in parallel with still gets just as hot as before, just as quick!! all this is with the new rad valves fully open.
So far i have done the following;
Shut off all upstairs rads, new rad got hotter a little quicker but still not anywhere as hot as the downstairs.
Removed the new rad and opened both valves into a bowl, got similar good flow from both.
Checked all now pipework for kinks and no problems found (didn't expect any as flow above was good) new rad is in parallel with existing rad so definitely connected to flow and return.
The only thing i am worried about is the 10mm microbore (plastic) has been connected using inserts to help them seal, these have an internal diameter of just over 5mm, but why would i get good flow with the rad removed?
Do microbore systems have some kind of flow restrictor in the upstairs manifold?
Really confused with this one, any help or advice would be priceless.
