My brain is in meltdown!!
vessy said:Problem is the new rad (1200x500 double) doesn't get very warm, all the other rads are hot to the bottom after about 10 mins but this one is only hot 1/3 of the way down. Strangely the rad it is connected in parallel with still gets just as hot as before, just as quick!! all this is with the new rad valves fully open.
Removed the new rad and opened both valves into a bowl, got similar good flow from both.
The only thing i am worried about is the 10mm microbore (plastic) has been connected using inserts to help them seal, these have an internal diameter of just over 5mm, but why would i get good flow with the rad removed?
Really confused with this one, any help or advice would be priceless.
