Did you do a felt roof on the new one? Since the very cold snap the felt on mine has wrinkled, i guess because Expansion of the osb roof and no elasticity in the felt, so it hasn't shrunk back flat
No I didn't want to risk any leaks doing a DIY job with the blow-torch (and the previous one was felt which failed prematurely but I suspect the roofer was a cowboy). Used a single piece of EPDM roofing this time. No problems with the cold snap thus far.
I noticed this winter our shed has had condensation dripping from the roof inside (wooden roof with felt).
I was thinking of fixing some Kingspan to the underside as that has kept the garage warmer and condensation free (from the roof)
I'm not sure?
I noticed some wet drips on the shelf tops and thought the roof was leaking, however it isn't but i can see some drips and feel the wetness on the inside of the roof. The thin single glass window (bonded to outside) has been frozen with the cold
The wooden floor is raised off the ground by a few inches (soil underneath), never had any damp in the lower part of the shed (floor/ walls)
It has a sloping roof which overhangs onto nothing so no gutters
The drips are all over the inside of the roof - at the lower/ highest and central points - no screws or nails poking through for the water to make its way through
