Right, did have a search of the forums, couldn't quite find an exact fit.
Have just had, rooms put in the roof of my 60s bungalow.
As is the norm, timber frame with plaster board and a skim of plaster over the top. So we have virginal walls and virginal skirting boards.
I have been painting the fresh walls (after a gentle rub over with fine glass paper) with a 3/4 paint (emulsion) and 1/4 water mix. Have got the odd little drop of this mix on the bare skirting and the wife has got very concerned saying I need to "seal" the skirting prior to any painting of them and these "drops" (and I have been wiping them off before they are dry) will ruin the skirtings.
Well not sure, but I though that if I run this mix over the walls first, I should then next gently rub the skirting down, then prime with oil primer and then finish off the skirting with a good gloss. Finally I then return to the walls and put the colour emulsion of choice on.
So;
Emulsion mix, prime walls
Rub skirting
Prime (oil) skirting
Gloss skirting (oil?)
Finish (Emulsion) walls
sound like a plan?
Steve, Canterbury
So;
Rub skirting
sound like a plan?
Steve, Canterbury
